Solved by spm8C88E. Go to Solution.
Maybe you have already checked here: https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Where-to-find-Revi...
All the content is there, but I would also add that there is a note about how to load families from the cloud in version of Revit after 2021. I've found this very helpful and easier than navigating through folders to find the families I need.
The Australian Content is in the Chris Hemsworth Folder.
P.S. Look under "Libraries".
