HOW TO CREATE A CURVED DOOR FAMILY
8 REPLIES 8
Message 1 of 9
ngurearchitect
834 Views, 8 Replies
I want to create a curved door family to place on a curved wall. I understand the basics of family creation but create a curved door seems complex to me.
Tags (1)
Labels (1)
8 REPLIES 8
Message 2 of 9
just drag your door family into your curved wall?
Message 3 of 9
Unfortunately the curvature on my walls means that solution does not work.
Message 4 of 9
post part of your door and wall here so we check?
Message 5 of 9
Is this an actual construction project or are you just modeling something? I have never seen a curved swing door in the real world before. I can find some images of curved pocket doors, but that's not what you have here.
Message 6 of 9
You could model a curved door as an In-Place Component in the Project to fit a specific curved Wall if you don't want to build a parametric loadable curved door Family.  That might be easier for you.  Even easier, would be to embed a curved Wall Type that was the same thickness and materials as your curved door panel and call this Wall Type "Curved Door".  😉
...I'm assuming that yours is a custom curved door since "curved" doors is not something you buy off the shelf. Am I reading you correctly? Yours are doors that will be specially built for your Project?
Message 7 of 9
Out of curiosity, are these doors pocket or slider types?
Can you share a picture of the real thing?
Message 8 of 9
dan_SAA
in reply to: ngurearchitect
Maybe: https://www.c-sgroup.com/doors/acrovyn-curved-doors ?
also: dynamicfenestration.com Lamoureaux-Architects_Ocean-Bluff_VancouverLamoureaux-Architects_Ocean-Bluff_Vancouver-5
Message 9 of 9
The principle is the same modeling any curved elements.  You control the radius and the width based on:
