How to Create a Curtain Wall Door Family?
hliS658H
Message 1 of 9
hliS658H
I create the railing fence using curtain wall and need to add a gate. So I should create a curtain wall door consisting of railings. Is there a curtain wall door family template?  What is the best way to create a railing door (curtain wall door)?
Replies (8)
Message 2 of 9
alan.johnson7YLND
A door in curtain wall would be a curtain wall panel.
There is a family template to create curtain wall panels. And a door one to create a curtain wall door
There are some generic curtain wall doors in the Curtain Wall Panel folder in the standard library.
Message 3 of 9
Yien_Chao
well you have 2 options. it could be a curtain wall panel family or a door family.
The first will adapt to your grids and won't appear in a door's schedule
the second will need a placeholder (a wall) to be able to insert the door.
both could have the same way to parameter.
hope that could help
Message 4 of 9
hliS658H
According to this thread, you can insert a door created with Door-Curtainwall template to the curtain wall and the door will show in the door schedule?  I am going to give it a try.
https://forums.autodesk.com/t5/revit-architecture-forum/curtain-wall-doors-do-not-show-up-in-door-sc...
Message 5 of 9
Yien_Chao
well, another workaround to get this is to create a multicategory schedule.
Message 6 of 9
Use this family template:
And yes, doors and curtain wall doors can be in the same door schedule.
Message 7 of 9
alan.johnson7YLND
Yes if you use the Door - curtain wall template it has the category set to door so should schedule as a door
Message 8 of 9
hliS658H
I have found a door-curtainwall family so no need to start from scratch. It has a glass door panel and material is grayed out, not sure where to change the material.
Message 9 of 9
The material is associated with a parameter.
