how to count volumes of certain elements
stevensonJQWEF
Message 1 of 8
stevensonJQWEF
Hey!
I would like to see how much volume of material is in the walls, floors and beams... (maybe without having to make my own calculations!)
Is there a way I can do this in revit?  If so, could someone explain to me in begginer (ish) terms please :))
Replies (7)
Message 2 of 8
JL.FCG
If you click your element, you should see 'Volume' in the Properties.
With this, you can create a schedule (Multi-category) and apply 'Volume' as a field!
Message 3 of 8
constantin.stroescu
use a Material Takeoff Schedule : View >Schedules>Material Takeoff - if you want to have all then use Multi Category
Constantin Stroescu
Message 4 of 8
stevensonJQWEF
Thanks very much for this!
Unfortunately though, in the list of scedule properties I am missing the option for volume...
Do you know why, or how to get it?
Message 5 of 8
stevensonJQWEF
I have the same problem unfortuantely...
I am missing the option for volume from the list...
Message 6 of 8
Create a Material Takeoff schedule then add [Material: Volume] field.
Message 7 of 8
stevensonJQWEF
Thanks Toan :)))
And nowww,,, I have a long list with Category and material:volume....
Is there a way I could see how many of these I have... or a way to include TOTAL volume of this category part?  (something like this??)
at the end i want to know how many m3 of columns, beams and flooring we are using
Thanks!
Message 8 of 8
Play with Sorting/ Grouping, untick Itemize every instance box, and set the Material: Volume field to Calculate Totals.
