How to convert Precast stair to generic model
shuaib009
shuaib009
How to convert Precast stair to generic model. I would like to make recess in landing for corbel as per the below sketch.
Below is the section for clarity.
Precast Panels are not shown in 3D image
L.Maas
There is no straightforward way. You could export the stair as dwg from the project. Then you can load that dwg in a Revit family. Then you could use the standard family tools to model over (parts) of the stair.
Louis
Please mention Revit version, especially when uploading Revit files.
RDAOU
@shuaib009
Keep the stair as stair...you do not need to remodel it all
  1. Edit Stair >>> Delete the landing >>> Finish sketch
  2. Model the Landing as a Floor Slab...these you can cut with a void
shuaib009
smart solution. thank you.
