How to convert coordinates from Google Earth to Revit
Hristina.Sokolovic
Hristina.Sokolovic
Hi, I am having problem with using Google Earth coordinates into Revit. I am not sure what is the format of coordinates used in Revit.
In picture 1, there are settings in Google earth
In picture 2, there are some coordinates from Google Earth
In picture 3, there are project units settings in Revit
In picture 4, there are coordinates that I need to write in. And I don't how what exactly I should write in.
In picture 5, there are setting for spot coordinates used in Revit.
 Can you please explain what is that I need to do.
    Thank you
scott_d_davis
Use a tool like this to convert lat/long to Northing/Easting:
https://www.latlong.net/lat-long-utm.html
Cut and paste the Northing number into "picture 4" in your post under "north/south" and the Easting number into Eaat/West.  Also fill in the elevation if you know it for your site.
Angle from project north to true north can be zero, and you can establish this again later if you need to.
Scott D Davis
Sr AEC Technical Specialist
RDAOU
@Hristina.Sokolovic
There is a Dynamo package called GIS2BIM which does that... Uses Google API and converts Longitude/Latitude or Address to Northing/Easting coordinates in Revit
