Hi @ffn2YJXN,
Sorry, controlling parameter values of a link by something in the Host model is not possible.
The Yes/No parameter in the family is not very effective if it's used to control the visibility of the text on views!
If actually hides the text in the family, and you want to hide it only in a certain view.
Some options, but always something needs to be edited in the model:
1. the owner of the linked model needs to edit their family so the text can be hidden with a viewfilter.
2. the owner of the linked model turns the text off in the family and prepares a view in that model where the families are tagged, this view can then be used as "Linked view"
3. You edit their model / family each time you get a update. Which means those different views can't be printed together, as the linked model needs to edited each time you want to switch the visible state of the text.
1. How to edit the family:
- A) Separate the Symbol (generic annotation) into 2 parts, one with the text and one with the symbolic lines.
- B) place the generic annotation with the text inside a Generic model, and make the Generic model shared (so it will only have that GA-family in it)
- C) place the Generic model family inside the Fixure family and link the correct parameter so the text value is passed to the nested GA-family.
- D) the Generic annotation family with only the symbolic lines can be loaded back into the Fixure family (as it was, but without the text now)
Now you can set up a viewfilter to filter out and hide that shared Nested Generic Model family that's inside the Fixure family. By it's name or something.
This also works in the Host, it can hide that Shared Generic Model family.
- Michel
Also:
"generic annotation of that category " => Generic Annotation is it's own category, Fixure category doesn't have it's own Generic Annotation category. So I don't know what the BIM coordinator was trying to communicate?
