How to combine 2 masses together
Message 1 of 82
I'm having some problems trying to combine 2 masses together when one is extruded out of the other. If you look at the up loaded picture 1. is the curved "curtain wall" and 2. is the arc. I'm trying to get 1 to fit in to 2 how do i do that any help will be useful thank you.
PS I'm pretty new to Revit.
Replies (81)
Message 41 of 82
yea should be @ToanDN
Message 42 of 82
@barthbradleyits doable on revit though right... how would you start it?
Message 43 of 82
I'd actually build it using real world capabilities. That's what I'd do. Formulating a design is easy. Making that design buildable is the real challenge.  You need to think framing. You've  got the skin.  Now, how is it supported?
That's how I roll.
Message 44 of 82
I see I would agree my self how ever I'm pretty lacking in the experience department. @barthbradley
Message 45 of 82
Break out the Popsicle sticks to add to your study model. Right now it's just paper.
...and give me a solution credit for all this great and free advice.  What do you say, champ?
Message 46 of 82
@barthbradleyits supposed to be a massing model so the whole thing is supposed to be a conceptual project.
In Addition, should i not figure out the grid lines first to know where the columns go?
Message 47 of 82
Conceptual? Then why worry about how to apply curtain walls? You got the conceptual design down pat, and it's pretty darn nice, if I may say so. Chipboard it and move on.
Message 48 of 82
No it is neither plumb nor rectangular.  You cannot replace it with a regular curtain wall door.  I suggest you, instead of  curtain system, create a wall by face and place a regular door in the wall.  Or, change the panel to a regular wall type and place a door in it.
For many reasons, a swing door should be plumb even it is placed in a tilted wall.  If you want the door to be tilted, it should be a sliding or awning door.
Message 49 of 82
@barthbradleyI'm struggling with it cause even though its conceptual the project wants me to put in a 3D model of it on revit showing exterior finishes and conceptual floor plan layout.
Message 50 of 82
@ToanDNwhat do you mean by plumb, i also want it too be a class wall so is there no way have that or do i have to change it to wood or something then put a regular door down?
Message 51 of 82
Plumb means upright, vertically straight.  You can make a wall by face and change it to have any material you want: glass, copper, gold, unobtainium, whatever...  It's actually perfect for conceptual stage.  I was trying to show you but you already deleted the mass surface, alas.
Message 52 of 82
@ToanDNhmm... is there a way to recreate that mass? However it doesn't seem like its letting me.
Message 53 of 82
No.  You have to redo it from scratch if you don't have a backup.  Do not ever delete the mass  again.
Message 54 of 82
@ToanDN
Oh man if only revit allowed remaking the mass again well i still have the file that you sent so I'm just working on that.
Another question is how to do diagonal curved wall which would not be accessible in Elevation views unless i do it using 3d view but that sounds difficult and there should be a more efficient way right?. Hope you will get my picture .....
Message 55 of 82
@ToanDNSo, I tried doing putting a store front wall on the mass to put curtain doors in but it would not let me make the curtain wall it said i can only use basic wall types only like the generic exterior wall or interior walls.
Message 56 of 82
Create wall by face and pick the surface. Do not use curatin wall tool.
Message 57 of 82
@ToanDNthats what i did but it wont let me "Wall type "Storefront" is incompatible with picked face. Only basic wall types are accepted."
Message 58 of 82
Use basic wall type and change the material to glass.
Message 59 of 82
@ToanDNk, thank you it worked out.
Sorry but i have another question can you put a floor in side a sphere mass?
Message 60 of 82
- Go to an elevation or a section and draw Levels cutting the sphere
- Select the sphere mass and use Mass floor tool, then select the levels to create mass floors
- Use Floor by Face tool to create Floors from the mass floors
