How to combine 2 masses together
Message 1 of 82
I'm having some problems trying to combine 2 masses together when one is extruded out of the other. If you look at the up loaded picture 1. is the curved "curtain wall" and 2. is the arc. I'm trying to get 1 to fit in to 2 how do i do that any help will be useful thank you.
PS I'm pretty new to Revit.
Replies (81)
Message 2 of 82
Edit the original mass and create a void form to trim the form of the curtain wall to match the other.
Message 3 of 82
....just tagging on to see if you give me the solution credit instead of @ToanDN.  Smiley Wink
Message 4 of 82
I am pretty new with revit still so I'm unsure how to do what you suggested.
Message 5 of 82
I'm not understanding what your trying to do. Join masses or join a mass to a curtain wall???
Message 6 of 82
I'm trying to join 2 masses together with out having the extrusions that you see in the picture
Message 7 of 82
That's the thing; a picture isn't clear. It kind of looks like they are joined already.
Message 8 of 82
Sorry, they are not joined instead i just made the arc mass first then the curved panel in a different mass and used reference point to draw the shape that i want in the arc.
Message 9 of 82
You cannot join different masses.  The forms must be created within one mass.
Message 10 of 82
But i would not be able to select the parts i want when i want to change the materials cuz the arc is supposed to be precast conc. and the curved panel is supposed to be a curtain wall
Message 11 of 82
The mass is to create the form. Then you create curtain system, walls, roofs by face by picking the mass surfaces. They can have different materials to themselves.
Message 12 of 82
okay another question its how to remove the extruding parts from the curved mass in the picture
Message 13 of 82
Since when? I must be misunderstanding, because I can join two different masses without breaking a sweat.
Message 14 of 82
how do you know whether the masses are joined or not?
Message 15 of 82
Ha! This is exactly what I was talking about. If they have no materials, it's not always apparent by looking at them; hence the reason they looked joined to me already. Anyways, try to pull them apart. If they move together or  turn orange and trigger a warning, then they are joined.
Message 16 of 82
So i found out they are joined but how do i remove the extruded parts of the curved panel?
Message 17 of 82
Well that's a bit trickier to describe. I'd need to have the file to figure it out. I'm still not sure what you have done or what you're trying to do. Sounds like your intention is to make a curtain wall from it. I don't think it's going to work the way you think, because you're applying a wall to the FACES of the mass.
Message 18 of 82
i have attached my file. I'm completely stumped on this.
Message 19 of 82
This doesn't help without knowing what you're trying to build. Do you have picture or something?
Message 20 of 82
This is the model I'm trying to crate with the knowledge i have so for on revit
