how to clean up stair stringer
nasibeh.montazeri
nasibeh.montazeri
Hi All,
is there any one to help me how can I make one clean stringer in my stair? the outer stringer is clear but the inner one I can not connect these 3 different stringer together:
mphungDCHNW
First select the stairs set you want to edit go into a plan view and drag the middle channel in between the 2 red circles in your image drag accordingly  and you will the stringer join together.
How would they connect in real life?
nasibeh.montazeri
exactly like the otherside of the stair(outside stringer). I have problem just for inside stringer
Do you realize that is physically impossible with your current landing layout?  The only way to get it is with a U-shaped landing.
kh_jea
Indeed. Or turn off "end with riser" for the first run and "begin with riser" for the second run.
