How to choose and select Textures between "Base" + "Low" + "Medium" libraries
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
This might be a "Newbie" question so I apologize in advance.
Can someone confirm how to use the higher resolution textures in Revit please ? I can't seem to find a way to do it.
I am adamant in that the "Base" + "Low" + "Medium" libraries were successfully installed.
In order to cross-check I can find all the textures in :
C:\Program Files (x86)\Common Files\Autodesk Shared\Materials\Textures\1 --> where the textures are 256 x 256 px in resolution
C:\Program Files (x86)\Common Files\Autodesk Shared\Materials\Textures\2, --> those are bigger with a resolution of 512 x 512 px
C:\Program Files (x86)\Common Files\Autodesk Shared\Materials\Textures\3 --> and finally the "medium" with the highest resolution of 1024 x 1024
However it seems that in Revit when I apply a material/texture it automatically defaults to the Base, lowest resolution of 256 x 256 px.
For the life of me, I can not find a way to select a higher resolution, or I am doing something wrong. In the next few weeks I am going to work on Room renderings and cabinets with relatively near close ups, where it makes sense to use the higher res textures. This workflow is going to last a couple of months.
So how does one "Set" Revit to pick/select into higher res textures ? Can you select (a higher res) on a case per case basis?.... is there something I completely missed.
Thanks for your help
