Hi, we are having the following issue while opening different views and sheets:
We tried:
* Opening on different computers
* Selecting "Audit" while opening
* Disable Hardware Acceleration
* Clearing the "temp" folder
How to check the view (not entire file) for corrupted elements (as this article suggests)? This can be possibly the last option.
Also, do you have any suggestions?
It will be a matter of trial and error. Assuming it only happens in this particular project.
Sometimes it is just the view that is the problem. Then deleting the view and creating a new one solves the issue.
Otherwise it is a matter of strategically deleting elements from (a copy) the project and see if the issue resolves at a certain time. You first could focus on suspect objects (highly detailed families, extreme shaped objects, objects containing non Revit content like autocad)
Louis
Please mention Revit version, especially when uploading Revit files.
sometimes you can get this information form the Journal file... check out this link:
https://www.linkedin.com/pulse/how-read-revit-journal-file-understanding-files-nauman-mysorewala
in particular, check out these categories in the article:
Howard Munsell
To check for elements which are causing the error, try turning off the display of elements in the view before opening it.
To do this, go through the following steps:
