HOW TO CHANGE WALL CUT IN 3D VIEW
christophervV7E3S
Message 1 of 8
christophervV7E3S
I have a 3d perspective of my model in an exploded axo. The walls cut are displayed in black. I want to represent the cut walls with the same color as the designated floor.  Is it even possible?
EDIT: These are not cut walls, they are displaced elements
Replies (7)
Message 2 of 8
Edit the 3D view type and change Coarse Poche Material.
Message 3 of 8
christophervV7E3S
Didn't seem to change anything, or didn't change the wall cut
Message 4 of 8
Set the view to Coarse first.
Message 5 of 8
christophervV7E3S
 Still nothing
Message 6 of 8
Are the walls being cut by a section box?
Message 7 of 8
TripleM-Dev.net
If walls have more than 1 layer, it takes over the Render appearance color for the top/bottom face of the wall from the material set in the Walls Category in Object Styles.
Change the render appearance color in the material attached to the Walls Category, If no material is attached it will use "Default Wall" material or a default grey color I think.
- Michel
Message 8 of 8
handjonathan
Hi @christophervV7E3S
Thanks a lot for posting your question to the forums!   Have the solutions suggested by @ToanDN @TripleM-Dev.net helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
