We have a site model and architectural model for this project.
The survey is linked to the site model and site model is linked to the architectural model.
The survey from the site model is visible in the architectural model, but for some reason, it doesn't shown up when I open site model separately.
The survey is put in a workset named as Linked_Survey, I have this workset open and visible. I suspect it might be put in some wrong workset, so I have all the worksets open and visible to the view, still, can't not see it. I also checked the imported categories and this survey file is being checked.
The survey file must be in this site model, since it is shown through the site model correctly in architectural model, where can it be possible hiding?
I checked the 3D view, it is visible there. I checked the work plane, and the survey is 0'-0" offset from workplane; I opened one of my archived site model which shows the survey in site plan, I compared the view range, they are exactly the same setting.
Gelöst! Gehe zur Lösung
Gelöst von hliS658H. Gehe zur Lösung
Okay problem solved! - just checked "reveal hidden elements" and it was there! - I never do that with linked files so nerve thought to check that. Whew!
