How to change topography contour line intervals after topo has been created?
james
Message 1 of 10
james
I understand how to use the Site Settings tool box to set the contour line interval when creating a new toposurface, but how to I change the interval once the surface has already been created?
Replies (9)
Message 2 of 10
Message 3 of 10
constantin.stroescu
click on the small arrow from Model Site and change Increment Value of Secundary Contours (2)
  • you can also  change the height interval between primary contours (1)
Constantin Stroescu
Message 4 of 10
james
Yes, the Site Settings tool box gives lots of freedom when creating a toposurface, but changing the contour interval value doesn't change the contours on my toposurface.
Whoops, my mistake.  This worked just fine.  Thanks!
Message 5 of 10
You can use Site Settings after you create the Toposurface to change intervals.
Message 6 of 10
ARRGH! Missed it by a hair.  I guess I should have included a Toposurface in the background of my Site Settings Screenshot.
Message 7 of 10
constantin.stroescu
Message 8 of 10
jenniferJ7YHR
This has been changed now and the selections under Model Site don't appear to be the same.
Message 9 of 10
vincent
Observer
Observer
Yep same problem. Rvt 2025 doesnt have the same options
Message 10 of 10
raksuoy
Community Visitor
Community Visitor
The contour interval setting is now a type property of the toposolid. Simply select the toposolid and 'edit type'. There you can edit intervals from 'Contour Display'.
