Can't erase some lines
Hi Friends, I got a Revit file and there are some lines that I can't erase them. Has anybodyCapture.PNG an idea? I attached the picture.
Can you select them?   Maybe you have a Selection Restriction applied.
dferreira-blackwell
are they annotation line then you can just delete them, try to unlink any links to see if they are yours or not. Share a part for proper identification if not solved.
Or maybe try to see if the line on the sheet over the view instead inside of views, so u can t delete them from activating the view , maybe they are just overlaying from sheet or any CAD plans.
ennujozlagam
The lines could be in the loaded families itself?. Thanks
ennujozlagam
Try to untick use hardware acceleration from option and see if helps. Thanks
