how to change the size of text label in this family?
615148142
615148142
Hi  please see the attached dishwasher family from Revit content library. I want to change the text "DW", but cannot find the way to do it.
I know how to add label into family and edit it, but this "DW" text seems not a label and I cannot find the way to edit the size. Please see the attached files.
Thanks in advance!
denis_borodin
I have really no idea how they made a symbol, which doesn't have Edit Family button). Try to create a new one
Denis Borodin, BIM Manager. LinkedIn
evan_grady
@615148142 Yeah I would just recommend remaking the family because for the purpose of what you need it does it have to be a symbol family? And if so, just set the sizing of the label text when making the symbol family
alan.johnson7YLND
You could keep using that Dishwasher family and just create a new annotation label.
Open the anno_label family from the default Annotation > Architecture folder
Edit the font size to what you want then load it in to the dishwasher family and replace the existing label, make sure to associate the label parameter in edit type properties
handjonathan
Hi @615148142
Thanks a lot for posting your question to the forums!   Has the solution suggested by @alan.johnson7YLND @evan_grady @denis_borodin  helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
Thank you so much!
