User property set - replace name of default parameter
mairh_tsek
mairh_tsek
Hello all,
I created a user defined property set and I want to replace both Height and Width parameter with my custom parameters Dimension "h" and Dimension "d" (see image)
I notice that in ifc file that I get my custom parameters are not exist. Do you have any idea?
Thank you!
You need to create a schedule, add IFC to the schedule title, add those parameters to the schedule fields, and use the following IFC export options.
mairh_tsek
Hello @ToanDN ,
Thank you for your time. It is not possible without schedule? I want to create the txt file instead of schedule
@mairh_tsek wrote:
Hello @ToanDN ,
Text file?  I am not understanding.  I thought you wanted to create IFC with those parameters.
mairh_tsek
yes I want to create an ifc file. But instead of using schedules for the user property set I want to do it with the option txt file (see image)
