hi everyone...
i m so confused! as per the file i have attached with this topic,
the green surface is a land of 350 acres! and i have to place those trees in proportion with the site! but i m not able to change the scale of the trees ..how do i do it?
as far as land is concerned, i imported a autocad 2006 block of contour map in centimeters unit...then i created the toposurface..my revit file project units are in centimetres..and my trees scale is in metres....
i m not able to import the contour block in meters unit...
please help me with this problem..
