How to change stair strings connection and join from diagonal to vertical ?
b.montarnal
b.montarnal
Hello everyone,
I have a problem I can't figure out about stairs structure.
I used a profile family that I created to make the stair structure on the picture.  Between the landing and the rest, the connection is diagonal, and I can't figure out how to make it vertical, as drawn in red in the picture.
I have already read this topic https://forums.autodesk.com/t5/revit-architecture-forum/stringer-cut-at-landing-revit-stairs/td-p/82... and the answer from @ToanDN , but it doesn't work in my case.
I attach the profile family if someone wants to test it.
Thank you in advance for your answer !!
I hope you would have an idea.. 🙂
Does anyone has an idea ?
martijn_pater
Perhaps model it as curtain wall. Or modeling in-place could be an option, that might be easiest tbh. You could even place it in railing support category. I don't really think you can get it the way you'd like using ootb stairs functionality. edit: I mean you could model it as baluster panel with a railing set to no connector for the joins, connection to trim, but you'd have to correct the offsets etc. just seems like a lot of trouble...
