How to change size/graphics of grid head/bubble
Hello, I am using Revit 2020 student version and I am working in 1/16" = 1' scale. I have my gridlines in place but the grid head and the numbers within it are quite large for the scale I'm working in . I was wondering how I can change the size of this. Thank you
Go to the Type properties of the grid and check the name of the symbol used.  Then go to families in your Project Browser and find that symbol.  Right click on that and edit the family.  Change it how you would like it to look.
kadmonkee
be sure to make a duplicate copy of your original prior to changing the size of your symbol and text Labels within each family associated with that particular family
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
Karol_Piroska
as well you can change the grid head/bubble to be parametric:
Is there a way of changing the color of the circle?  I need to produce a presentation drawing where it is required to make the grid less prominent
Thank you
