Revit error in CAD coordinates
2 ANTWORTEN 2
Nachricht 1 von 3
383 Aufrufe, 2 Antworten
I'm trying to link CAD plan drawing to Revit. Revit do read coordinates right but ignoring (.) in CAD coordinates. Instead of 179552.511 Revit reading it without a dot.
I did make sure units are the same and positioning is right.
please check attached pics.
2 ANTWORTEN 2
Nachricht 2 von 3
Alex_Figueres
als Antwort auf: Anonymous
It might look like your DWG is drawn in meters (Civil engineers often work in meters). Then, if you link such a CAD file in your Revit drawing and get coordinates from it while having project units set to mm, coordinates are shown in mm, thus 1000 times larger than in meters, which in turn seems as if Revit is ignoring the point/comma.
Check your Project Units to meter and see if coordinates "become correct". See a video of how you change Project Units here:
 https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2019/EN...
Nachricht 3 von 3
s.borello
Check your units in your CAD file, this could be why there is a discrepancy.
