How to change groups of title block
tcardia
tcardia
Hi to all!
I have a model that is only used to take plans, in this one there are groups of plans with a title block, other groups with others title blocks, etc.. My need is to change title block to a sheet group with a new title block, but I don't want it to change the title block to other groups.
It would be simple if I could pull out a plan table and its associated title blocks, but I can't find a way.
Does anyone have any ideas to achieve this!?
Thank you!!
Alfredo_Medina
If there are certain titleblock types already applied to certain groups of sheets, then this is easy. You can go to one of the sheets in one group, select the titleblock, then do: select all instances > in project > assign the new title block. Then all the sheets in that group will change their old titleblock to the new one.
If all existing sheets have the same titleblock now, then this is not easy, you will have to manually assign the titleblocks. Unfortunately, the titleblock is not a property of the sheet, so it's not possible to do this from a schedule.
