- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hey folks, I have racked my brain and cannot find a solution for one of the easiest calculations.
See the attached schedule and calculated value. I'm simply trying to take the area of my building and divide it by the total room count to get the average area of a room in the building. This is for a self-storage facility and the average storage unit area is an important statistic.
In my schedule I added the "Unit Count Number" parameter to the rooms. Each room has a value of 1. I did this because I could not use the default "Count" parameter in a calculated value.
In my schedule, you can see then that I have column "C" "Unit Count Number" which is totaling the amount of units of each size (5x5, 10x10, etc...) and then has a grand total at the bottom of the column.
Additionally I have the "Area" and "Marketable SF" (Marketable SF is a custom parameter I made for each room because what we market round number areas rather than exact areas so this value is slightly different than the Area parameter calculated by Revit) parameters which is also totaling the area for all the units of a size and then has a grand total at the bottom of the column.
All I want to do is have the "Average Area" column display the Area/Unit Count Number or Marketable SF/Unit Count Number. and have it give me an average size per row and a grand total at the bottom of the column. You would think this is simple enough but it doesn't seem to work. You can see my image of the calculated value I setup. I think I am doing it correctly, but in the schedule it's dividing the areas by 1 so that the Average Area, is the same number as the Marketable SF. Why is this? Why can't I get it to calculate properly?
For example the 5x5 units have a count of 122 units and a total marketable SF of 3050 so the Average Area should be 25 SF (3050/122) Likewise the grand total at the bottom of Unit Count Number is 1160 and the total Marketable SF is 108350, so the total Average Area should be 93.41 SF.
Any ideas on how to get this to behave?
