How to break wall sweep/baseboard at different rooms
lorissa
lorissa
I have two rooms, but when I draw in the baseboard as a wall sweep, it goes through the wall.  Also, as the baseboard in the bathroom is tile, and the baseboard in the main space is wood, how do I separate these?
Split the wall between rooms.  Or, use grips to stretch the wall sweep.
I don't see the baseboard going through the wall. I see the baseboard on the face of the wall below what appears to be a window. The baseboard is within the view range. You're looking down from the cut plane to the floor; right?
Actually, there way too much linework in that view. What's going on? Did you apply a transparency?
tomas.polakCMEY6
Check out this tutorial, it might help you:
https://youtu.be/pkYIqua0XR0
Tom
Tomas Polak
ARKANCE
