How to associate multiple Schedule lines to a single Revit element
Hi all,
I have this issue with Revit schedules for Curtain wall mullions.
The curtain wall has on top the mullion named "HA" which is scheduled properly in a single line, but that mullion is composed as well by different profiles/sub-component (such as TB12345 and TB78910).
For now I just placed it as parameters of the mullion "HA" but
I need it to display in the schedule as single instances therefore single lines for each profile TB12344 and the others.
I dont need it to be real modeled component (families) but just information associated to mullion HA and displayed in the schedule in their own lines.2.PNG
Any suggestion? Is it somehow clear?
Many thanks
Can you elaborate? What do you mean by "that mullion is composed as well by different profiles/sub-component"
“PROFILO 1” is a parameter of “HA”, thats why I managed to schedule it like that.
I d like to schedule it as a independent instance but I think it is not possible because it s just a parameter.
I also tried to place a detail component inside the profile of the curtain wall mullion but it does not appear as shared and neither in the schedule.
The bigger picture is that I have to schedule a curtain wall mullions but each mullion should be formed by several profile, as it is made by the constructor.
The best option would be nested mullion but Revit does not allow it.
Create a Multi-line text parameter to enter the profile information in the schedule.
For now I managed to obtain the desired result with the help of a Dynamo script, very powerful.
