How to assign a global parameter to a set of dimensions?
I try to assign a global parameter to a number of dimensions.
If I understand right, the "Label Dimension" Widget should be available after selecting a dimension as shown in the following screenshot:
In my case, however, even after selecting a dimension it is not visible:
Am I missing something?
Dietrich
Sorry for posting twice.  I got an error message after hitting the [post] button - and the advice, to try again in a couple of minutes.  That's what I did...
By the way, is there a way to erase a message after posting it?
semko_dm
Hi!
Global parameters are available only in Revit 2017 and in Revit 2016 R2. What version do you use?
Also, global parameters are unavailable for Revit LT.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Dmitriy Semko.
Dmitriy Semko
BIM-Manager
Blog
Facebook | Telegram | LinkedIn
Hi Dmitriy,
Thanks for your answer!
I use Revit LT 2017.  Unfortunately my company cannot effort the full version of Revit.  So this is the reason.  Too bad...
I searched the internet quite a while and couldn't find any information concerning the absence of this feature in Revit LT.  This page, for example, rather gives the opposite impression:
  - Global Parameters
Do you know about an internet page with a list of the features absent in Revit LT to which I could refer to in similar cases in the future?
Thanks and kind regards,
Dietrich
semko_dm
Hi, Dietrich.
You can find a complete comparison <on this page>.
Also, take a look <at this page> its include some information about Interoperability between Revit LT and Autodesk Revit.
Dmitriy Semko
BIM-Manager
Blog
Hi Dmitriy,
Thank you. I have searched the comparison page before - but obviously overlooked the part about global parameters...
    Features > Advanced modeling > Global Parameters: supported in Revit - but not in Revit LT.
Too bad...
Thanks again,
Dietrich
