- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have made a simple roof by extrusion as shown, and the ends need to be cut off using the reference planes already in place that I used previously to cut the structural framing beams with the simple "cut geometry" tool (clicked on beam, clicked on reference plane, voilá!) but when I tried to do the same roof, I can't select the reference plane as the "second-click" of the cut operation.
The roofs' "Rafter cut" is set to "Plumb Cut" which is doing half the job already, and I could just edit the extrusion reference line to end at the reference plane to get at least the vertical cuts right, but I would still need to get the roof to end at the horizontal reference plane in order for the roof to end in a "point"
I know that beam family types need to have a "void extrusion" in order to be applicable for cut operations in the project, but do roofs as well? I'm using Revit's "Roof by Extrusion" and applied a "System Family: Basic Roof" structure to it
Am I using the right roof tool, or is there some setting I need to enable? Thanks!
[ The subject line of this post has been edited for clarity by @handjonathan Original: How to cut a roof wi]
