Linhas coloridas em planta baixa
2 ANTWORTEN 2
Nachricht 1 von 3
ThuanadeSouza
99 Aufrufe, 2 Antworten
Olá pessoal, estou com o problema de as linhas estão aparecendo configuradas na cor magenta conforme mostra imagem a seguir. Já verifiquei a visibilidade gráfica e não consta nenhuma cor associada a algum desses elementos.
2 ANTWORTEN 2
Nachricht 2 von 3
Simon_Weel
als Antwort auf: ThuanadeSouza
Those are probably Room Separation Lines. Model Categories > Lines > <Room Separation>
Nachricht 3 von 3
ThuanadeSouza
als Antwort auf: Simon_Weel
Hello, it's not the < Room Separation >
from what I've seen, it has to do with the View Range. In the view range, when changing from ground level to basement level, the lines return to the correct color.
I'm attaching 2 images, even with the problem solved, if you change the view to ground level, the colored lines return
