How to add finishing layers to column?
How to add finishing layer to column
Finish layers will be architectural, not structural....so just add a wall around the column with the proper material.
Yien_Chao
If its for scheduling, i wouldn't add a 3d model layer around it, but instead create a shared parameter For the input finish.
samuelsanf
Yo can create architectural colums arround structural colums, they get wrapped. But I don't think it would work on schedules.
Structural material should let you to add non structural layers for wrapping (it's no easy to wrap a cincrete beam on Revit not painting all their faces... Not always they are hidden by ceilling, and you have wrapping it with finish layers). Also, placing a architectural colums only for wrapping structurals ones is not a efficient way.
J. Samuel Santana F.
¿Te resultó útil esta publicación? Dale a Me gusta.
¿Tú pregunta fue respondida correctamente? Haz click en el botón ACEPTAR SOLUCIÓN.
samuelsanf
One option that you should try it to customize the column family to add the wrapping layer. If you want the layer in the model.
