How to Add Fill Pattern (.PAT) library into Revit?
Trinh_TH
Trinh_TH
is there any way to add my Fill Pattern (Draft & model) into Revit fill pattern list?
Because each time, I need to select a Pat, I go through the Path to get just 1 file and I don't know the preview of the pattern before adding it into revit
What about adding the finished fill pattern to your template (RTE)?
...otherwise, use Transfer Project Standards to transfer the fill pattern between projects.
