how to activate the rendering tools in revit 2017
hi autodesk/and users:
can you assist me how to activate the necessary rendering tools for my revit 2017 trial..thanks
There is a button under the view tab called render.
constantin.stroescu
you can activate renderer either from :
  1. View Control Bar -internal Renderer
  2. Ribbon >View Tab - two options Render (internal) and Render in Cloud ( if you have credits)
Constantin Stroescu
constantin.stroescu
I 've forgot the screenshot:
Constantin Stroescu
thanks for the quickie reply. i am privy already to your helpful advise, but my problem is , after i do what you advised,
it gives me a totally black image. it remains like this even if i do adjustments to exposure.
i remember when i downloaded the program yesterday,i saw a 2 second pop-out that says the rendering commands are not activated,
i just kind of disregarded it. now i am into the problem.can you give me some kind thoughts.
thank you very much
It means your material library has not been installed....  Take a look here:
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/EN...
