how to activate temporary dimensions manually between two lines
chhuanmawia18
chhuanmawia18
temp dimensions 3.jpgtemp dimensions2.JPGsometimes revit snaps the temporary dimension line points at ridiculous points that they are often dificult to drag and re-place the points where i want them to measure  . is there a way to use the temporary dimension tools like that of the regular dimension tool by selecting two lines that we want them to measure
L.Maas
No, there are not (many) settings for temporary dimensions.
The settings that are avaible can be found under Manage > Additional Settings > Temporary Dimensions
The temp dimensions that show up can be repositioned by using the blue dot to another element, but that is as far as it goes.
Other option would be to use regular dimensions
Louis
Please mention Revit version, especially when uploading Revit files.
chhuanmawia18
Thank you!
