attaching a screenshot.
I received a dyn script from somebody for randomizing glass color, tried using it in my project and it wouldn't work. I'm new to Dynamo, first script. I think it has to do with the parameter name (Element.SetParameterByName)- the code block attached to the paramter name. What exactly do i need to fill for a parameter name?
Once this is fixed, is there a way to f.e to have 60% of one color 20% of another and so on?
when I did this I used to randomize the curtain panel types. So, instead of materials, you would random shuffle panel types (each type has a different material, of course).
In your script, please expands all data going through your nodes, and the error message you are getting, otherwise it's difficult to see what is going on.
On top of my head, I think you are trying to change the material of a curtain panel type, which is useless if you only have one type of panel on your model (all your glass will change at once, depending on the last material you assigned to the type).
Also, "Material" should be a type parameter, so I am not sure it will work if you feed it instance elements, as you are.
If Material was an instance parameter, then your approach would make more sense.
Regards
gio
no, didn't abandon it but i hope they both get answered. here i got further a bit with an actualy dyn script. i'm still alive in both of them ![]()
