When i rename a Plan, revit then show a dialog asks if you want to rename the corresponding views. Usually i just manually respond yes/no, later i then decided to check the "Do not show me this message again." before click the "Yes" button and since then, everytime i rename a view plan, it automatically rename all the corresponding views, even when i work on another project. Is there a setting to revert this back since the confirmation box no longer shown up, and i don't want revit to Auto-rename the corresponding views anymore
Thanks in advance
Solved by ToanDN. Go to Solution.
Find this line in your c:\Users\{yourname}\AppData\Roaming\Autodesk\Revit\Autodesk Revit 2022\Revit.ini file and delete it to reset.
"SuppressConfirmPlanViewRename"
...as per the link I posted above:
...or, if you haven't customized the default INI, you could just close Revit, delete the INI file, and relaunch Revit.
@aaidinalimsyah wrote:it worked, Thanks!
So, typing a "0" over the "7" was too much work, huh?
Must be a generational thing. In the old days, we repaired things. Not like today where you just throw away stuff that ain't working.
Sad.
