How make sheet size parameter without moving texts
ehsan_elahi
ehsan_elahi
Community Visitor
Community Visitor
Hi.
I want to make a sheet family for my project with different sizes (A1-A2-A3-A1+...) How make sheet size parameter without moving texts?
I make the sheet in title block and make dimension for sheet and give them a parameter, but when I change dimensions, the texts moving, or maybe the lines around texts moving. I want that the part of texts and project information lock and stay in their position and the size of sheet increase or decrees on the other side of sheet.
thanks
vitorbortoncello
Make another title block just for the project information
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
dAutodesk Certified Professional
There are dozens of video and tutorials on-line of different approaches to building Titleblocks. Google and watch them all. But my very strong suggestion is to build separate and differently-sized Titleblock Families instead of fussing with building one Titleblock Family having many parametrically-sized Types.
SteveKStafford
I'll echo @barthbradley - the amount of available room for TB information varies quite a bit for each sheet size so making it adjust for different sizes is tedious. However, you can create groups of elements that need to move and use a dimension to move them via a parameter. It's possible, it just gets trickier the more you have to alter what the TB needs to look like for each size. So you have to decide if the ability to choose a different size in one family is "easier" for the end user than just choosing a different family for the other sizes.
Steve Stafford
