How is the U value calculated in revit?
a88129
a88129
In revit, how is the U value calculated for floors, roofs and walls? Can we access these values in the program or are we the ones who have to define them? Is the value of Rsi e Rse defined for each type or is it generic and do we have to rectify the calculations for our values in the situations they are not the same? Is the Rsi value 0,04 or are different values considered for different situations?
handjonathan
Hi @a88129
Thanks a lot for posting your question to the forums!   Has the solution suggested by @barthbradley helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
