So I did as suggested by @constantin.stroescu and used the Eccentricity instance property of the Wall Footings in order to center them on the wall core. But now I come into a different problem:
When intersecting a different footing, the footings tend to extend with an equal amoount as the Eccentricity I have set for the footing that they intersect.
I have attached my Revit model. In it you can see:
- On the T.O.F. Low structural plan:
- the footings on grids A, B', B extend futher than the footing on grid 3 by en aqual amount as the set Eccentricity for the footing on grid 3. Interestingly though only the footing on grid A extends futher than the footing on grid 1 (even though the footing on grid 1 also has it's Eccentricity changed)
- the footing on grid 2 retracts by the set Eccentricity amount of the footing on grid C.
- On the structural plan T.O.F. High
- similar occurences, plus the footings on grid 2 completely fail to cleanup with the footings on grid D'
- There are several such instances in the 2 floorplans where these extensions occur. I have marked most of them by dimmensions which are equal to the set Eccentricity for the respective footings.
The question is then: is there any way to clean this up correctly? Obviously they all clean up correctly if I give up on using the Eccentricity instance property and just let them center on the overall wall thickness, but I would prefer them to center on the wall core rather than the overall wall.
The Revit Help system states for Foundation Slabs, in the Structural Engineering->Foundations-> Foundation Slabs section that: "Foundation slabs may also be used to model complex foundation shapes that cannot be created using Isolated or Wall Foundation tools." I suppose I can try to model the foundations for my house using Foundation slabs 45cm thick, but is there maybe another way to do this?
Many thanks in advance.
