Also, on the shotcut assignment screen (KS), there are "Place center of rotation" and "Center of rotation on center of selection set" options (I don't recall the latter existing before RVT2026).
The former allows you to launch the rotation tool with the "point selection" option already active, regardless of the last time you used rotate.
Both, once the rotate tool is activated, allow you to switch between both modes (Selection or Center).
If you put them in nearby shortcuts, it makes for a lightning-fast workflow. I have them in R3 and R4.
Now that I think about it, it would be nice if the second one also activated the rotate tool, you would save 1 shortcut.
¿Te resultó útil esta publicación? Dale "Me gusta".
¿Tu pregunta fue respondida correctamente? Haz clic en "ACEPTAR SOLUCIÓN".
