How do you insert a window into a cylinder?
maybe its easy and stupid but not for me ;/ How can I make hole in cylinderic wall?
dzanta
All default window families (i.e. single flush, etc.) are meant to go into a straight wall.  They have a built-in Opening object that cuts the host wall.  For a curved wall, you will need to create a curved window such that the radius of the window is parameterized so you can change the curvature to match that of the curved wall.  The opening for the window will most likely need to be a void extrusion that can cut the host wall perpendicular to the face of the wall.
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
