How do you change thickness of the leader to an unassociated callout head?
David125
Message 1 of 9
David125
I loaded an callout head from the annotations family to place an unassociated callout head. When I place a leader it is extremely thin. How do I change the thickness.  I don't know what to look for when I go to object styles.
Replies (8)
Message 2 of 9
ennujozlagam
you can go manage > additional settings > arrowheads > type properties and set from there. thanks
Message 3 of 9
David125
Thanks for the response but it's not the arrowhead that I have the issue. See the image, I'm trying to make the thickness of the leader line on the callout match the leader line thickness of the text leader.
Message 4 of 9
ennujozlagam
is this you wanted it to be. please see screenshot. then type TL to show the tickness.thanks
Message 5 of 9
Message 6 of 9
David125
Changing this setting did change the thickness of the leader lines on associated callouts. It had no effect on the generic unassociated head. The unassociated callout that I placed was done using SYMBOL from the symbol panel on the ANNOTATE tab. That has to be a different system family than associated callouts. I still can't find it.
Message 7 of 9
David125
 Found it!
Message 8 of 9
ennujozlagam
did you mention about generic annotations in your post? thanks
Message 9 of 9
I think I understand what you are doing now.
You are adding a Leader to a Symbol in the Project, and that Symbol Family's Line Work is assigned to a custom Subcategory which uses a thicker weight than the Generic Annotation Leader Line  in the Project.
I have a suggestion for you that you may like better:  Don't change the Symbol Line Work in the Family.  Leave it on the Parent Category and using the Parent Category's Line Weight and Pattern.  Instead, use Overide Graphics in View: By Element(s) to change the Line Weight of both the Leader and the Symbol together.   You could even set up a View Filter to do this.
I can readily see where changing the Category Line Weight for the entire View could be problematic.
FWIW
