HOW DO I SPLIT A 3D MODEL INTO TWO PIECES
dawilgos
Message 1 of 11
dawilgos
Imagine cutting a cake in half and pulling the two pieces apart slightly. Allowing you to see the inside levelsElectionCake_halves.jpg
That is what I want to do with my project while in 3d view.
Does anyone know how to achieve this?
Replies (10)
Message 2 of 11
bin
Yes, try the displace elements.
or you can create 2 isometric view with section boxes to cut half of the project and place them onto one sheet.
Message 3 of 11
dawilgos
Unfortunately neither of those options allow what I am trying to achieve. Thanks though
Message 4 of 11
bin
Like this?
Message 5 of 11
RobDraw
It sure looks like what you asked for. Try describing exactly what you are trying to achieve.
Rob
Message 6 of 11
aRcHiTeCt.JM
... hi @dawilgos
... as @bin said... like this ?
... is there any other way?
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
Message 7 of 11
The Saw Tool.
Message 8 of 11
RobDraw
Maybe the OP wants to split the model in half so as to insert something into the gap. The saw tool would be the right answer.
Good one @barthbradley!
Rob
Message 9 of 11
...or this tool:
Message 10 of 11
RobDraw
That must be a demolition tool. It works as designed but not as expected.
Rob
Message 11 of 11
dawilgos
For some reason I don't have this tool available. I'm using Revit 2020. Is it in this version??
