How do I remove existing Guide grids from template?
d.dillon
d.dillon
How do I remove old Guide grids from a project template?
The company has few previously-created Guide Grids in their template.
Nobody here knows of the origin of these Guide Grids.
How do I remove the existing guide grids from the template file?
I will create new ones that will have relevance to what my company is currently doing.
Thank you
AGGilliam
After placing the guide grid you don't want on the sheet, select it and press delete.
d.dillon
AGGilliam:  That worked.
I was looking for a "purge" feature or some other process.
Thank you for your time
In order to remove them from the Template (RTE), you would need to not only delete them, but also Save As Template.  To do this, Open a New Project using existing Template, Delete Grid Guides and then go to File=>Save As=>Template - and overwrite the existing one.
ahmadM69EF
How to remove them from sheet but not deleting them. I will use it later on and already using it on different sheet?
Thanks mate
Thanks mate
Highlight a bunch of sheets in your project browser and set Guide Grid to <None> from Properties.
ahmadM69EF
Thanks mate!
