How do I measure lengths on slanted surfaces?
Message 1 of 14
How do I measure lengths on slanted surfaces from mass ?
Replies (13)
Message 2 of 14
Change workplane to the slanted surface and measure the distance.
Message 3 of 14
sqrt(a^2+b^2)
Kidding Smiley Happy
Message 4 of 14
revit refuse to make workplace at slanted surfaces at my case , ill send photo to see what i need .
Message 5 of 14
Sahay_R
Create a reference plane, name it, align it to the slanted surface. When you go to set workplane, this will show up in the list of workplanes to select.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 6 of 14
chrisplyler
@Anonymous wrote:
revit refuse I DON'T KNOW HOW to make workplace at slanted surfaces at my case , ill send photo to see what i need .
Open a 3D view. On the tool ribbon choose Architecture > Work Plane > Set and then choose the Pick a plane option. Now click on a slanted bit in your 3D view.
Message 7 of 14
I completely mean Revit refuses to choose a surface
You can see that when I select the desired surface you will find that it chooses the intersection line ,not the surface and this is the problem
With your thanks and respect for your attention
Message 8 of 14
Did you use Tab to cycle through the selection?
Message 9 of 14
Certainly
I am an old user of the Revit program, and this will not be missed.
Respect and appreciation,
Message 10 of 14
Maybe the surface is not planar, but warped.  Create an adaptive generic family with two points and snap it where you want to measure, then list the length.
Message 11 of 14
I think you are correct , i'll try to solve it ,
Message 12 of 14
Alfredo_Medina
@Anonymous
You cannot select a surface because the option for selecting elements by surfaces is off.
This is a screen capture of the taken from image that you posted:
Message 13 of 14
@Alfredo_Medina
I don't think that affects the ability to set the workplane by face.
Message 14 of 14
Alfredo_Medina
You are correct. I just read post # 7 above, and in that post the user just says "Revit refuses to choose a surface" while his toggle button to select an element by surface is off. That post does not mention that what the users wants to do is to set a workplane. Now I know. 🙂
