Hi all,
In my project I'm giving some information on the plan manually. But the information I give I can set also in the room properties. So I did set these fields with the right information as you can see in the screenshot. But now I would also like to use these parameters in a new room tag. But when I wanna edit a new room tag I cannot acces or see these parameters under the list of parameters that I can choose from creating room tags
Should there still be a possibility to use these parameters in a room tag?
regards andy
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
