How do I make the brick lines darker
sully00
Message 1 of 48
sully00
Thin lines does not seem to do the trick see pic what I mean I want to make the brick lines darker so when I zoom out is displays darker.
Replies (47)
Message 2 of 48
Change view scale.
...and turn off Thin Lines.
...BTW: Brick is a MODEL Pattern.
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/Revit-C....
Message 3 of 48
sully00
does not seem to work just want to show the brick in detail or what view should I set it at?
Message 4 of 48
Brick isn't going to show "detail" when you zoom out really far.  Basically, no difference from the real world.
Message 5 of 48
linkboy
like this?
Message 6 of 48
sully00
so how can I show brick in detail when zooming out?
Message 7 of 48
Isn't that the same question I answered above?
...if you want a consistent surface pattern, use a DRAFTING Pattern.
Message 8 of 48
Revit omits dense pattern on screen when zooming out for performance reason.  If you want to print the view out with pattern then give it a larger scale and increase the PDF output resolution.
Message 9 of 48
sully00
This pic is what I am trying to replicate
as you can see when zoom to fit the brick is not clear.
Message 10 of 48
sully00
how ?
Message 11 of 48
@sully00 wrote:
when I do zoom to fit the brick never shows see pic.
Crop the view and zoom extent.
Message 12 of 48
sully00
No does not work I can only see the bricks when in drafting view not model view for some reason.
Message 13 of 48
Are you using a drafting or model pattern for the surface pattern of the brick material?  Please show the graphic tab of the material definition.
Message 14 of 48
Can you make out all the individual bricks in this photograph?  No, of course, you can't.  But they are there. Thousands of them.
More on visual perception here:
Visual Perception - an overview | ScienceDirect Topics
Message 15 of 48
sully00
see pic I have to change to drafting view to see bricks more closely
Message 16 of 48
sully00
yup I am learning thank you
Message 17 of 48
I posted this above.  Did you read it?
About Drafting Patterns and Model Patterns | Revit 2019 | Autodesk Knowledge Network
Message 18 of 48
You are using a drafting pattern as shown in your screenshot so it will not present correctly the brick pattern.
Use a model pattern instead.
Message 19 of 48
sully00
When I do Model brick, I zoom out and brick is not clear but when I zoom in closely it is fine see pic.
Message 20 of 48
mhiserZFHXS
You realize that, if the pattern showed when zoomed out, it'll just make the drawing black right? That's (one of) the reason(s) they disappear.
You're missing the point that, even though you think you want them, you really don't want those lines showing when zoomed out.
