How do I get the same data given by results and compare?
- Mute
- Permalink
- Report
So I have read through the forum results for what has happened to the "Results and Compare" section. The response seems to be that it has been replaced by insight. This would be fine but I need the results part not the compare part!
A cost comparison is useless to me for what I want from an energy analysis. I am using the latest version of Revit (2019) but this seems to have less functionality (as per https://forums.autodesk.com/t5/revit-architecture-forum/result-and-compare-window-missing-in-revit-2... and https://forums.autodesk.com/t5/revit-mep-forum/revit-results-and-comparison/td-p/7145175).
What I would like to do is export my results in some format (as requested in this post: https://forums.autodesk.com/t5/insight-energy-forum/export-results-to-pdf/td-p/6952909) but I can't find any way this is possible. This seemingly should have been done 18 months ago.
So please rather than simply advising me that results and compare has been replaced by insight can you please tell me how I get the results. Is it possible through insight or will I need to use a legacy version of Revit? Are these even viable solutions?
Thanks in advance, Robin Jones
