How do I create a fine-meshed raster ceiling?
kristian
Message 1 of 10
kristian
Hi
I want to create a raster ceiling with about 100x100 millimeter squares but I can't figure out the proper way to do this.
This is what I've come up with so far - I created a Roof instead of a Ceiling and then I chosed "Sloped Glazing" as the type. I then modified the mullions to fit my needs, they are 25x40 millimeters. I also changed the Curtain Panel to "Empty". All good so far but the problem begins when I try to set the fixed distance to 100 mm as the ceiling itself is 20x80 meters. Revit tells me that the maximum gridlines of 200 is exceeded and tells me to split the affected walls(?) "if I really need this many type driven grid lines".
I totally understand this problem and I'm sure there must be a much better way to do this... But how??
Thanks in advance.
Replies (9)
Message 2 of 10
RDAOU
@kristian
Logically speaking, if you were to execute such a ceiling (20 x 80 meters!!), you would split it into several parts with control/Expansion joints. Hence, do it that way using slopped glazing
OR use 2 Beam Systems as per below GIF
Message 3 of 10
kristian
@RDAOU
Thank you very much.
I tried to split it up in 15x15 meter parts just to see if it worked and it did. I will test the beam system idea as well (why didn't I think of that in the first place? 😆)
I found this: https://www.bimobject.com/en/barwa-system/product/open_cell which seems to be exactly what I'm looking for. I can't figure out how to use it though. I'm pretty new to Revit.
Message 4 of 10
RDAOU
It is an easy thing to model why would you want to look for 3rd party families?!
Message 5 of 10
kristian
As I said - I'm new to Revit and I like to explore many different solutions just to learn the best way to face a problem. Yes it may be easy to model up but next time it may be not so easy.
I was just curious to know how that 3rd party family was meant to be implemented. Nothing more, nothing less.
Trying a beam system now...
Message 6 of 10
It is just a generic model created from importing 3d geometry from another application into the Revit family as freeform elements.  There are some materiality and product data, but they are not parametric in terms of geometry.
If you are doing design then use beam systems or sloped glazing for flexibility.  Both sloped glazing and beam system have member quantity limits so simply create your very large design from composition of smaller areas.
Message 7 of 10
kristian
Thank you!
Message 8 of 10
kristian
I made two beam systems and it worked pretty well except that it for some reason skips one small area and I can't figure out why..? If I change the boundary it skips other areas and create new "holes" randomly. (Maybe it's just too much for my computer to handle...)
Also. Is there a better way to draw this ceiling - preferrably a way to make it lighter and not so complex? How would you draw this? Any ideas? There just have to be a better way...
Message 9 of 10
RDAOU
@kristian
Yeah there is an easier and much lighter version
  • Ceiling + Material Cutout
Message 10 of 10
kristian
@RDAOU
Funny... I was just reading about Cutouts, as we speak. 😁
Will try that instead. Thank you!
