How do I add a door to a storefront wall against the horizontal grid/mullions?
jstolber
Observer Observer
jstolber
Observer
Observer
I am currently using Revit 2022 and I'm having trouble adding a door to a storefront wall. I have included the settings to get the correct sizes for the panels. I have also highlighted in the photo where the door needs to be and how to get it to take up that entire space while also removing the mullions. Any help would be appreciated. I can also clarify anything if you need. Thanks. Settings for wallSettings for wallHighlighting where door needs to beHighlighting where door needs to be
You need to remove grid segment to create a larger Panel that you can replace with a CW Door Panel.
Just to be clear here: Select the GRID LINE to activate Add/Remove Segments on the Contextual Tab.
- Select grid crossing the opening > remove segment.
- Select the curtain panel (unpin if you see a pin), change it to a Curtain wall door (load a curtain wall door family in  the project first)
- or, select the curtain panel (unpin if you see a pin), change it to a basic wall type, place a regular door in that wall
- Don't forget to delete the mullion segment at the door threshold (or change to a mullion type with the threshold profile)
jstolber
Observer
Observer
I got it, thanks for the help!
