How do I add a basement?
I need to add a basement to my building so how do I do that PS i talking a bottom level (exp:
——————————second floor
——————————First floor
—————————Bottom floor (basement)
Sahay_R
For basement the level would be added at a -tive level. So if First Floor is at 0, Basement will be at -something.
In a section / elevation view, add the level.
View>>Plan Views>>Floor Plan
You will be prompted to select a level. Select the Basement.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
kadmonkee
open an elevation view copy the level designation and define the distance below the First Floor you want it to be.
then create you floor plan and Ceiling Plan views for that level.
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
